SBC provisioning failure
orange2
I've just deployed 2 SBCs on Proxmox vm's from the ISO to give me extension access into 2 customers from here. One went exactly to plan. URL and auth key accepted and all is good. The second, also a pretty plain vanilla config is refusing to accept the SBC URL & key with error "does not accept the SBC Auth key ID xxxxx. Any ideas how to sort? PBX is working absolutely fine on AWS.
if you try the id's for the second SBC on the first , does it connect ?
most probably not your case, but I ask anyway, could you have done a partial mix in SBCs credentials?
Have you tried creating a new SBC in 3CX? Make sure you save the SBC before trying to connect to it.
Diogo Maia
