Schedule Conference from 3cx WebClient > MS365 calendar integration > Edit text template-default?
fortech
small fun question. Just getting a small 3cx setup for a client today, and trying to use the built-in workflow,
- web client
- schedule conference
- use the 'calendar' drop down to designate Office 365
- create the conference, it nicely passes things over to web MS365 Outlook / calendar / creates a meeting in the calendar there
By default it has quite terse blob of text, basically says, "Dial in ### / Conference Code // Staff may dial 700 and then use COnference Code".
If we use the Calendar drop-down for "3cx" style it instead provides a more verbose message / based on a template / which is easy to edit.
I'm curious if there is some way to give a slightly more verbose / customized 'text blob' for the MS365 integrated calendar flow method
or if that is basically not going to happen
or if anyone knows a work around, ie, manually edit (this secret file) under the hood to make the change to this boilerplate blob of text ?
Thanks!
Tim
Footnote on this thread, I did find some customization in the 'email' customization area, so I'll poke there for a start. If anyone else feels like commenting still that is great. Thanks!
Hi @fortech,
You can customize the email that is generated in more detail by logging in to your Management Console >> Settings >> Conferencing >> Conference Email section >> click Configure. I think this is the functionality you're looking for.
gmacinit
