Scheduled Backup Option Missing
mr_synapse
On one of my 3CX hosted instances I don't see the "Schedule Backup" option. It's missing. I thought I remembered seeing it before I configured an SFTP target in the "System > Storage" section, but who knows. Any ideas why this option is gone?
The scheduled backup option is found under the System > Storage section.
I am aware of that option, but it looks like that only control scheduled configuration backups, right? Is this below option different, or does it do the same thing?
I guess what I am looking for is where to adjust the frequency and retention for SFTP backups. From what I can tell, perhaps this is not an option and the only option is to adjust the "Auto-archive older than" field? Is that right?
The schedule is for when the backup will be run, and since it's archived to an SFTP, the backup will be archived there once it is completed.
I understand that, but that does not answer my question:
I guess what I am looking for is where to adjust the frequency and retention for SFTP backups that are not configuration backups (chat, fax, recordings, voicemails). From what I can tell, perhaps this is not an option and the only option is to adjust the "Auto-archive older than" field? Is that right?
I think you have the gist of it.
Summary
1. Backup Frequency and Retention Settings:- For SFTP backups in 3CX, you can schedule backups to occur "Hourly", "Daily", or "Weekly". You can also set a backup rotation, which determines the number of backups to keep before overwriting the oldest one.- The "Auto-archive older than" field is used for managing the retention of recordings, voicemails, and other non-configuration data. This setting allows you to specify the number of days after which these items should be archived.
2. Limitations for Non-Configuration Backups:- The frequency and retention settings specifically for non-configuration backups like chat, fax, recordings, and voicemails are not as flexible as those for configuration backups. The primary method for managing these is through the "Auto-archive older than" setting.In summary, while you can schedule the frequency of backups and set retention policies for configuration backups, non-configuration backups rely on the "Auto-archive older than" setting for retention management.
Even more summary - Anything that's "Archive" doesn't get rotation - if you need to delete old items of those types you should use other means - OS scheduled tasks for example.
