Solved Server error after upgrading to SP6
lreiber
I upgraded from SP5 to SP6. Everything went fine and received message that the upgrade went fine.
When I try to log in as admin it comes back and says server error and does not log me in.
I rebooted the server and the same thing happens.
Any idea's what I should do so I can log in to the system
Hi Ireiber,
If running the system on Windows perhaps look at the services on the server and see if any of the 3CX services have stopped. If Debian Linux there should have an equivalent command also or view services (I believe the location is) /lib/systemd/system/.
That was it. All the services started except for one.
Glad to see the issue has been resolved and thank you for updating the thread with your solution.
Bluebox Global
