Server recommendations with RAID 1 hardware config
mdkberry1
Can anyone recommend server hardware that will work with the following:
Software: Elastix 2.3
Max concurrent calls 60-100 (SIP Extensions only no Analog requirement)
RAID 1 hardware controller (not software raid or fakeraid)
>1TB disk space(All calls will be recorded 24/7)
NIC 1000mbps
Redundant power supply.
I would like to use the HP Proliant range or Dell, the biggest issue being that it must work with RAID 1 hardware level config as I will be providing image backups and software/fakeraid does not work with imaging.
looking at the HP DL360 G7 range now for this
yarusemiKK
