set external CID for remote office callers (extentions of another 3cx instance)
Evgeniy L.
Hi!
Please advise how to set CID for outgoing calls made by extensions from branch via bridge?
Scenario is:
Site A has sip trunk with 2 DIDs (default and extra)
Site B connected to Site A with bridge.
I've made outgoing rules on site B to route outgoing calls addressed to Site A country code via Bridge
Site A also have rules for outgoing rule for calling outside via SIP trunk.
I need to set CIDs for outgoing calls this way:
Calls from site A extensions have default sip trunk's DID as CID (and it works)
Calls from site B extensions have CID=extra DID of SIP trunk (now they get default DID of SIP trunk)
Hi!
Scenario is:
You should be able to set "Outbound Caller ID" in your extensions of Site 2. This field should be used by default by 3CX.
Hi, Frederick!
Unfortunately, this setting does not play any role in this scenario :(
Call comes to Site A with caller ID = virtual extension of Bridge
"Outbound Caller ID" works only for Site B sip trunks (and I also need it working there with Site B local numbers)
[email protected].
