setup obi200 with 3cx?
Song
Do 3cx support obi200 setup? I read some forum it should work. But this is what i'm trying to do. We have a SIP provider with 3cx and that is setup already. So in theory i would configure the obi200 to use a sip account on the 3cx and assigned a DID incoming and route it to the sip account of the obi200? and for outbound I would do the same? is this setup ok to do? will it work.?
If so can someone point me to the setup on 3cx or obi.
thank you in advance.
There have been a number of posts, on the forum, for using an Obi with 3CX and Google voice. Do a Google search. Some include configuration examples. The 3CX profile would be pretty much the same, and rather than GV, you'd register the other profile to a provider. However, if you are attempting to connect to another VoIP provider, then skip the Obi and register them direct to 3CX. The 200 only supports a telephone, not a PSTN line, so it can't be used as a PSTN gateway.
[email protected].
