- Joined
- Feb 6, 2018
- Messages
- 11,209
- Reaction score
- 7,033
Hey guys,
We are currently exploring multiple cloud storage solutions and right now we are testing Files.com. It's pretty solid and offers FTP and SFTP support.
When trying the SFTP connection, the connection itself works (as well as in FileZilla) but backups are failing (FZ can upload/download files without issues).
Here's the error log we get:
We opened a ticket with 3CX but unfortunately so far the only thing they said is "it's supposed to work, it works for everyone else" (which I agree) but why us?
We tried multiple protocols (FTP, FTPS, FTPES, SFTP) and none works. FTP(es) gives an error about invalid configuration.
The SFTP is using credentials (no public key) and the path is fairly simple:
Any ideas?
This is on our 3CX Pro v16 U4.
Code:
System.Exception: Renci.SshNet.Common.SshException: Upstream Error During Data Transfer.
at Renci.SshNet.Sftp.SftpSession.RequestWrite(Byte[] handle, UInt64 serverOffset, Byte[] data, Int32 offset, Int32 length, AutoResetEvent wait, Action`1 writeCompleted)
at Renci.SshNet.Sftp.SftpFileStream.FlushWriteBuffer()
at Renci.SshNet.Sftp.SftpFileStream.Seek(Int64 offset, SeekOrigin origin)
at System.IO.Compression.ZipArchiveEntry.WriteCrcAndSizesInLocalHeader(Boolean zip64HeaderUsed)
at System.IO.Compression.ZipArchiveEntry.DirectToArchiveWriterStream.Dispose(Boolean disposing)
at System.IO.Stream.Close()
at System.IO.Compression.WrappedStream.Dispose(Boolean disposing)
at _3cxNetBackupAndRestore._3cxBackup.ZipFile(String dst, Stream src)
at _3cxNetBackupAndRestore.BackupTasks.BackupOMTask.BackupOM(BaseTask task)
at _3cxNetManagement.BaseTask.Run()
at _3cxNetBackupAndRestore.BackupTasks.BackupMappingTable.BackupTable(BaseTask task)
at Renci.SshNet.Sftp.SftpFileStream.Dispose(Boolean disposing)
at _3cxFilesystemImplementations.SFTP.FixedSftpFileStream.Close()
at System.IO.Compression.ZipArchive.CloseStreams()
at System.IO.Compression.ZipArchive.Dispose(Boolean disposing)
at _3cxNetBackupAndRestore._3cxBackup.FinishingTask()
at _3cxBackupRestoreImpl.BackupRestoreUtils.Backup(IFilesystem filesystem, String instanceId, String cfgPath, String dbConnectionString, BackupConfig options, String fullpathFilename, Boolean sendEmail)
at BackupRestoreSchedule.BackupJob.Execute(IJobExecutionContext context)
sftp://company.files.com/BackUp.Any ideas?
