- Joined
- Nov 27, 2022
- Messages
- 35
- Reaction score
- 13
I love that SharePoint is supported for a backup destination now. (My struggles with setting up backup over SFTP are discussed here previously[1].)
However I hope that it is on the To Do list is that a different site can be selected
The root SharePoint site is by default the "Team Site"[2] and has read-write permissions for "Everyone (except external users)." Thus any user in the tenant could read the contents of the backup, and could alter it such that different permissions and settings would be created on restore! (ZIP password allowing.)
I suggest you add such a note to https://www.3cx.com/docs/manual/sharepoint/ saying something like "Note that by default the root SharePoint site has permission "Everyone (except external users)." You should adjust the permissions on the destination folder as appropriate for your environment."
Alan
[1] SFTP backup in 3CX apparently writes the ZIP file in random-access mode, ie rewinds to update the ZIP header on completion. Many SFTP destinations including Azure only handle writing a file in one go! There's a setting in 3CX to disable the random-access mode but that isn't available in Hosted.
[2] EDIT: Ohh its a "Communications Site" on new tenants now, but the permissions are the apparently the same.
Alan
