SIP ALG detection failed using Mikrotik
pichewy
Hi, I am trying to finish up installing 3cx onto a rasberry pi. Everything went smoothly until I tried testing firewall check. All tests pass except for the following:
  • testing 3cx server.... failed
  • detecting SIP ALG ... failed
I have a mikrotik router and did configure the firewall settings as described in 3cx documentation, and also enabled SIP services in Mikrotik for port 5060 and 5061.
I am a bit lost on what else I should look for to fix this problem?
Any help or tip much appreciated!!
Disable SIP in IP Services on Mikrotik and try again, also you can post mikrotik firewall/nat settings here
Thanks for your reply and help!
I did disable sip service ports in Firewall>Service Ports.
Here is the firewall print...
0 X ;;; 3CX Presence and Provisioning HTTPS
chain=dstnat action=dst-nat to-addresses=[ServerLanIP] to-ports=5001 protocol=tcp dst-port=5001 log=no log-prefix=""
1 ;;; 3CX SIP UDP
chain=dstnat action=dst-nat to-addresses=[ServerLanIP] to-ports=5060 protocol=udp dst-port=5060 log=no log-prefix=""
2 ;;; 3CX SIP TCP
chain=dstnat action=dst-nat to-addresses=[ServerLanIP] to-ports=5060 protocol=tcp dst-port=5060 log=no log-prefix=""
3 ;;; 3CX SIP TLS
chain=dstnat action=dst-nat to-addresses=[ServerLanIP] to-ports=5061 protocol=tcp dst-port=5061 log=no log-prefix=""
4 ;;; 3CX Media UDP
chain=dstnat action=dst-nat to-addresses=[ServerLanIP] to-ports=9000-10999 protocol=udp dst-port=9000-10999 log=no log-prefix=""
5 ;;; 3CX Tunnel TCP
chain=dstnat action=dst-nat to-addresses=[ServerLanIP] to-ports=5090 protocol=tcp dst-port=5090 log=no log-prefix=""
6 ;;; 3CX Tunnel UDP
chain=dstnat action=dst-nat to-addresses=[ServerLanIP] to-ports=5090 protocol=udp dst-port=5090 log=no log-prefix=""
This is what I use for mikrotik
chain=dstnat dst-address=publicip dst-port=5060 protocol=udp src-address-list=voip-provider-ip-list to-addresses=serverip to-ports=5060
I just use winbox to look at what ips are slamming the firewall on 5060 when I run the test and add them to the allowed list of ips, otherwise 3cx test servers will always be blocked unless you just have 5060 open to the public.
Thank you 3cxnub. I think I have the port 5060 opened via NAT. Unfortunately I am using Mikrotk and the dns filtering is not available.
I use next two NAT rules in my MT
Code:
/ip firewall nat
add action=dst-nat chain=dstnat comment="3CX Phone System" \
dst-port=5090,5060,5061,5001 in-interface-list=WAN protocol=tcp \
to-addresses=[ServerLANIP]
add action=dst-nat chain=dstnat dst-port=5090,5060,9000-10999 \
in-interface-list=WAN protocol=udp to-addresses=[ServerLANIP]
and disable SIP ALG
Code:
/ip firewall service-port
set sip disabled=yes
[email protected].
