SIP ALG Issues on Firewall Checker right now?
cbpr
Hey there everyone,
Currently across all 3 of my PBXs they are getting the SIP ALG error. It doesn't seem to be causing any major issues as I can see, but thought it was worth mentioning.I saw that this was an issue that came up in December of 2017, but wanted to make sure if it was just the SIP ALG reporting that wasn't working.
I checked all our firewalls and everything has SIP ALG disabled.
Thanks!
Hi cbpr,
What firewall models are you using ? I would say that most these days have a GUI based tick box which enables the switching on/off of SIP ALG but I have known one or two brands which require SIP ALG to be turned off on a CLI command, and sometimes both.
Or is this an issue that has occurred after working OK for some time.
Hello @cbpr
Thank you for reporting this. Can you retry now as it seems there was an issue on our side which has now been resolved.
megalmazan
