SIP or DID
Gary RR
New User
Good day
Currently have a SIP in the Netherlands and trying to decide whether to get a DID or a SIP for the UK market.
The DID seems to be the cheaper option but wondering if a SIP would be a better idea?
Other than it being a fail over is there any additional benefit?
It's not one or the other.
A DID number is an option, if you have a SIP trunk. If you have DIDs, it means you require more than one number, and the provider can send the DID information, in the Invite, so that you can route the call as desired. The alternative is one number assigned to the trunk.
You can add DIDs to a SIP trunk, but you can't have DIDs without one (at least, in the SIP world).
Thanks leejor
I do understand that you need a SIP in order to have DIDs attached as it is not a stand-alone.
The question I am trying to ask is..
Is it better to have a number as a SIP or a DID if the number is for a different location...
Thus, is it better to have:
SIP (Netherlands)
- DID (England)
- DID (Germany)
- DID (Italy)
- DID (France)
OR
SIP (Netherlands)
SIP (England)
SIP (Germany)
SIP (Italy)
SIP (France)
Currently I have it set up as SIP with DIDs per region however wondering if it would not be better to have as separate SIP accounts to allow more control and hoping for experienced people such as yourself to weigh in from past experience. :)
In order to have a DID, you have to have a SIP account. If the provider you are planning to use in one country offers DIDs from others, and that is what will work, then go for it.
In most cases, to get a phone number from a specific country, requires that you have a SIP trunk in that country.
If you require a German telephone number, you get a German SIP trunk, you can then add DIDs as required. The German company probably won't supply UK DIDs. You'd have to get a UK SIP trunk for that. Of course there are exceptions, and there are SIP providers that offer phone numbers from a number of countries. Of course, you will pay a premium for that "convenience".
So...you can order a SIP trunk, with one number, and route that number as required. The trunk will support more than one call, depending on what you are paying for. If you require additional numbers, then you order DIDs, which will be less than the initial cost of the SIP trunk. You can then use DID rules, in 3CX to route the calls as required.
It will come down to what the provider allows (will the provider allow you service if you are not located in their country), and how are you getting the call to the destination. Whether it is the "main" number assigned to a trunk, or a DID that is added, makes no difference.
Reactions: Gary RR
Diogo Maia
