SIP Trunk Template
Walter Santos
Where can I get the template file for siptrunk? mysiptrunk_pv.xml
if your sip trunk is 3cx supported one then template is included in 3cx, just add trunk, select country and search your sip provider, after that you just need to add credentials received from your provider , done.
Yes I know that. The provider is not homologated 3CX, but the system itself says that it is possible to customize the default templant to make it appear in the dropdown of available providers.
I would like the template to import the provider into 3CX. When I try to import, I have this information.
"Select a SIP Trunk template file to import. A SIP trunk will be created with all exported settings. Enter your Main Trunk number or DID / DDI Number and press OK."
Sorry, never used this Sip feature in 3CX , so i'm not the guy who can help on this one :confused:
[email protected].
