Solved SIP Trunk with third party PBX
siscom
Good Afternoon Colleagues
I hope you are doing good . I need to configure SIP trunk between 3CX & Third Party IP PBX . Here are the details:
  1. Extensions at 3CX: 1000 to 1099
  2. Extensions at third part IP PBX: 2000 to 2099
I can successfully route calls from 3CX to third party IP PBX using the appropriate outbound rule.
So when incoming call from third party IP PBX received at SIP Trunk , Which configuration should be done at 3CX to forward calls automatically to 3CX internal extensions 1000 to 1099 ?
Best Regards
Use a master bridge instead of a SIP trunk. This way, inbound works as well.
Thx Frederick . It worked perfect for me
Kayla Norris
