Sizing Up A Server For WebMeeting Resources?
oguruma1218
Forum User
I currently run 3CX on a Pi 3. It works fine, but I'm going to move it to a KVM server.
Is there a good set of guidelines on how much I should allocate to it by way of CPU cores/RAM? Does the number of Sim. Calls and WebMeeting Participants Make a difference?
Hi @oguruma1218
The webmeeting does not run on the PBX, the session is hosted by our own cloud MCUs that handle the traffic load, so whether you are on a Pi or 64-core EPYC cpu wont make a difference to you.
x1515
