Skill based routing
Alphabetic
3CX MVP
I need to create 1 Q so that the wallboard reporting is correct with abandoned calls. But I need to have it ring x users first before trying another x users.
is it yet possible to achieve this in one queue?
I need next skill level to ring if no answer after x seconds
Hi @kieferschild,
Yes you can set up SBR RA (Ring All) and then divide your agents by skills as you've defined in the Agents tab.
Hi @kieferschild,
Will this definitely ring agents in skill level 2 even when level 1 are available and not answering?
Ah now I get what you're saying, and no - that's not possible.
As per the Academy, it'll only move on when an extension is unavailable which I'm sure you already knew. I thought maybe of using the legacy Windows Client with the auto-status timeout change, but honestly since it's legacy it's better not to try and implement it as a a solution.
It'll just have to go to another queue and call reports will have to do. @VoIPTools has something for this I believe I've read in the past...
This question has been asked many times before. The only solution that I can think of is to dynamically add and remove designated overflow agents to the queue when the SLA is breached, and remove after the numbers fall below a threshold. This would require custom development. We can help.
megalmazan
