SMS with VoIP.ms
mobileradiocom
So, when i press the “save” button, it does not
behave the same way as it does when I save any other fields in the configurations. When trying save the “sms” data, the “save” button does nothing. It doesnt take me back to the trunks page as you would expect. You can click it and see it change colors when clicked, but nothing happenes. The page just sits there. If you navigate to another tab, then reclick the sms tab, everything is cleared/gone. I have tried several browsers, including Chrome safari and edge. I have tried it on a Mac, windows, 11, and my iPad and get the same results with all of the machines.
I followed the guidelines step-by-step and it’s working. The only problem is that they can only receive SMS and not send SMS anyone know what’s problem?
I followed the guidelines showing how do the setup with voip.ms, just cent get the setting to save. Does it mean anything that the installation is a StartUP? And i’m on version 20. Just wondering if that matters
I also followed the guide and got it to work but I can only receive incoming SMS on my DID. I cannot send. The error message in events log says:
Failed to send message(s) to the provider 'generic' from 'xxxxxxxxx' to 'xxxxxxxxx'. Exception: {"errors":[{"code":"10009","meta":{"url":"https://developers.telnyx.com/docs/overview/errors/10009"},"title":"Authentication failed","source":{"pointer":"/"},"detail":"Could not find any usable credentials in the request."}]}
I'm on 20.0 Update 2 (Build 715)
Any ideas?
SupportRock
