SMS
rbergthold
I have a Voxtelesys SIP trunk set up with SMS enabled. I have one of the SMS enabled DIDs assigned to a user. As that User, i am able to reply once a message is sent to me. Is there any way that I can the party that originates the SMS? Or, is it just meant for replying to already received texts?
Can you please clarify what you mean?
"Is there any way that I can the party that originates the SMS"
i see that I am able to reply to a text that is already sent to me. Is there a way that I can send a text without it just being a reply to one already started by somebody else sending to me? Can I start a NEW text?
Hi @rbergthold,
You can send a SMS message, before doing that you need to make sure that you are using E164 formatting otherwise your outbound messages will not leave the 3CX.
E164 formatting is: +18885551234
* DIDs in the Trunk need to be set that way
* Inbound and SMS trunk need to be set that way in our portal (is by default)
* Outbound number is set that way when creating the SMS chat
Creating an SMS chat.
1. In the webclient go to Chat
2. Click the + sign then Send SMS
3. Enter the number you want to message (Example: +18885551234)
4. Select the number you want to send the message from
yah. i'm a crackhead. i just forgot the kindergarten steps to get there. it works easy-peasy. Have a wonderful weekend!
ARKC
