Snom D315 not updating internal phonebook
Philein
as the title says I am seeing that no update is pushed to the internal phonebook (the one you reach pressing the Directory button).
Rebooting or reprovisioning the phones doesn't help.
Any tips?
How are the phones provisioned?
I reset them and they appears in the list
Just to clarify, you now have factory reset and is working?
Yes if i factory reset the phone it works correctly (it shows all the updated extensions)
Ok, after the provision it does not update?
What is the provisioning method and firmware version?
The firmware is 10.1.141.10
What other information do you need?
How is the phone provisioned Local, STUN or SBC?
Is it local on the same location where the PBX is also installed?
Yes! Same LAN and ip class
When you manually press to update the phonebook, do you receive any error?
On the phone directly, go to the phonebook and press to update.
Finatra.us
