Snom M900 Adressbuch
Matthias Florian
Hallo zusammen,
werden beim SNOM Dect System M900 mittlerweile das komplette Adressbuch synchronisiert oder gibt es hier noch Einschränkungen?
Kann in den Anleitungen leider nichts dazu finden.
Vielen Dank.
VG
Hi @Matthias Florian you can use this German forum https://www.3cx.de/forum/
The M900 can get the phonebook as you may see in the provisioning template
<!--### PhoneBook Settings ###-->
<phonebook_server_location>0</phonebook_server_location>
<phonebook_reload_time>%%param::phonebook_update_snom%%</phonebook_reload_time>
{IF network=LOCALLAN}
<phonebook_location>%%PROVLINKLOCAL%%/</phonebook_location>
<phonebook_filename>snom_phonebook.xml</phonebook_filename>
{ELSE}
<phonebook_location>%%PROVLINK%%/</phonebook_location>
{ENDIF}
Just make sure not to use special Characters in names, also validate with the vendor what is the contact limit for the device.
Hello Alejandro,
okay, will all of a contact's phone numbers be synchronised, or just the mobile number?
Perhaps you could answer my question briefly.
No, only mobile number. There isnt any change... You can try the script in the german forum for converting the phonebook.
Reactions: Matthias Florian
Does the script also work with cloud PBX systems that are operated with an SBC connection at a remote location?
If you have access by ssh, than yes. Not on hosted by 3cx.
