Snom mobile conferenz
Rmn3
Hi Guys,
i could need your help.
We are using the Snom M65.
While a call you can use the conferenz button on the mobile phone, to create a conference.
It is a cool feature, because you can first ask the colleague if he is available to take a call, before you forward a customer call to the colleague in charge.
But since a few days, this feature strikes. When an employee of us want to use this confernce button on the phone, the system says user is denied.
What can i do?
Thanks in advance.
Hi @Rmn3,
What base is being used?
Also have you tried to factory reset both and reprovision, then try again?
What do you mean base?
Yes, nothing has worked
It should be the m700
Stephan Eusebe
