snom PA Series | Configuration Guide
KaterinaK_3CX
Hi!,
we use the PA1 in germany as door opener and also for triggering hooters by incoming calls.
So what we have to do here to get it work again after the 3CX update 5?
We have provisioned the PA1 manually so does these PA1 worked nevertheless after Update 5?
Also Snom has the brand new PA1+ as follower. Does 3CX support the news PA1+ ?
regards
Hi!
The guide has been updated with the steps you need to follow to make sure the PA1 will still work.
As for the new PA1+, our interop team is currently testing it.
Hi!
Which guide updated you mean? On this Link https://www.3cx.com/sip-phones/snom-pa1/
there is only for Manually Configuring Snom 300, 320, 360, 370, 820, 821, 870 phones. So does this also apply for PA1 ?
It's a cache issue. Clear your cache and you will see the updated version.
Stephan Eusebe
