Softphone multiple extension configuration
stono
Is there a way to setup multiple extensions to be registered simultaneously on a singe 3CX softphone instance for inbound calling and be able to pick from multiple extension for outbound calling?
The idea is to be able to answer calls coming in on different DID's routed to specific extensions and call out on those specific ext/DID's by selecting the extension to call out on.
Currently I can only be logged into one extension at a time and have to go to Configure Account and change the active account to a different extension to be able to use that extension for inbound and outbound calling.
Simple answer is no,
What you are currently doing is the only way
Hello @stono
Please note that the 3CX client supports only one account to be registered at a time so you will need to switch between them if you want to use multiple accounts on one 3CX client.
megalmazan
