I tried to go to phone to add softphone but nothing listed there, so I went to extensions and I added extensions,ID and password, and I tried 3cx softphone to registered but doesn't show not connect so I tried to zoiper softphone same thing doesn't register
If you've added extensions, with email addresses - you will receive a Welcome Email which will attach the instructions to log in to the Web Client. It will also include a QR code which you can scan using the 3CX Mobile Client which you can download from the Play Store / App Store.
I'd take a look at our 3CX Academy which covers the use of the 3CX system from start to finish here: https://www.3cx.com/3cxacademy/
Note that 3CX includes a softphone, so no need for Zoiper.
Hi @VasilisV_3CX
I tried to login via web client and working fine, but the configuration file i received by email with extension 3cxconfig i can't run, it is open to me via notepad, how i can import to softphone app? i tried also to do provisioning via web client but nothing done
one more thing in case customer doesn't have internet connection how i can configure manually his soft-phone app without Welcome email
The Welcome Email contains a config file which works using the 3CX Windows Client. It isn't necessary, as you can log in using the Web Client (which the Welcome Email explains how to do with a link and username / password).
