Solved SOLVED recieving whatsapp messages but unbale to reply - get little red crosses
RichT
Hi, set up WhatsApp integration today, when i sent 1st message from mobile and heard my 3cx app ping, I celebrated a little too soon, because i cant reply to the incoming messages, I get a little red x and the sender doesn't get the replies :-(
I'm hoping it is a simple thing i have missed?
thanks
Richard
Hi @RichT
Do you see any errors in the event log?
Good Point Nikolas and yes loads!! I'll go do what it says tokens or permissions and try again - thanks very much - forgot to look there
Reactions: NikolasA_3CX
99th time luck i guess - all working now :-) Thanks Nikolas
NortechTelecom
