- Joined
- Mar 31, 2019
- Messages
- 66
- Reaction score
- 5
| 04/11/2020 10:49:29 PM - STUN discovery of public IP is disabled |
| 04/11/2020 10:49:29 PM - Exception: DumException Cannot create new sessions when DUM is shutting down. @ DialogUsageManager.cxx:517 |
| 04/11/2020 10:49:09 PM - Set log verbosity to MaxLevel = 2, Severity mask = 7 |
| 04/11/2020 10:49:09 PM - Loading Contact records from database |
| 04/11/2020 10:49:09 PM - Line 90000 has been updated from DB |
| 04/11/2020 10:49:09 PM - Dev(1450585941):[sip:90000 / 90000]: PBX contact is public IP: <sip:90000@XXX:5060> |
| 04/11/2020 10:49:09 PM - Signal: stopHandler got: 15 |
| 04/11/2020 10:48:59 PM - Failed to add outbound CID reformating rule for DN:10003: <Rules /> |
| 04/11/2020 10:48:59 PM - Line 10003 has been updated from DB |
| 04/11/2020 10:48:59 PM - Dev(452529583):[sip:[email protected]:5060 / XXX]: PBX contact is public IP: <sip:XXX@XXX:5060> |
| 04/11/2020 10:48:41 PM - Currently active calls [none] |
| 04/11/2020 10:48:39 PM - Failed to add outbound CID reformating rule for DN:10002: <Rules /> |
| 04/11/2020 10:48:39 PM - Line 10002 has been updated from DB |
| 04/11/2020 10:48:39 PM - Dev(1162158051):[sip:[email protected]:5060 / XXX]: PBX contact is public IP: <sip:XXX@XXX:5060> |
| 04/11/2020 10:48:19 PM - Failed to add outbound CID reformating rule for DN:10001: <Rules /> |
| 04/11/2020 10:48:19 PM - Line 10001 has been updated from DB |
| 04/11/2020 10:48:19 PM - Dev(XXX):[sip:[email protected]:5060 / XXX]: PBX contact is public IP: <sip:XXX@7XX:5060> |
| 04/11/2020 10:48:11 PM - Currently active calls [none] |
| 04/11/2020 10:47:59 PM - Failed to add outbound CID reformating rule for DN:10000: <Rules /> |
| 04/11/2020 10:47:59 PM - Line 10000 has been updated from DB |
| 04/11/2020 10:47:59 PM - Dev(279808887):[sip:[email protected]:5060 / XXX]: PBX contact is public IP: <sip:XXX@XXX:5060> |
| 04/11/2020 10:47:41 PM - Currently active calls [none] |
| 04/11/2020 10:47:39 PM - Supported Mime Type added:MESSAGE(x-chat/control) |
| 04/11/2020 10:47:39 PM - User-Agent's that is configured to ignore: friendly-scanner,sipsak,smap,Elite 1.0 Brcm Callctrl,sipcli,VaxSIPUserAgent,VaxIPUserAgent,PortSIP,friendly-request,sip-scan,sipvicious,sundayddr,iWar,SIVuS,Gulp,sipv,siparmyknife,Test Agent,eyeBeam release 3006o stamp 17551,SIP Call,PortSIP VoIP,Conaito,Ozeki,Gbomba,MizuPhone,VoIP v11.2.4,VoIP SIP v11.0.0,VoIP v11.1.2,sdfsfsdfsdfdf,Nmap NSE,BaSeL-X,dr.pes,Z 3.14.38765 rv2.8.3,pplsip,sipptk,eyeBeam release 3004t stamp 16741,eyeBeam release 3007n stamp 17816,eyeBeam release 3010n stamp 19039,MGKsip,Z 10.14.38765 rv2.8.3,A_B_C,UsaAirport,KPhone/3.14,zxcvfdf11,eXosip,eyeBeam release 3015c stamp 27107,SipClinte2019,yarab100,eXosip2,SipReg v1.0,IPOffice,VoIP SIP |
| 04/11/2020 10:47:39 PM - License loaded sucessfully. License level: 2 |
| 04/11/2020 10:47:39 PM - Secure SIP (IPv6) is available at XXXXXX |
| 04/11/2020 10:47:39 PM - Secure SIP (IPv4) is available at XXXXXX |
| 04/11/2020 10:47:39 PM - Adding secure SIP transport (IPv4) for sXXXs:5061 |
| 04/11/2020 10:47:39 PM - [CM506005]: Public IP=XXX is used for WAN communications through local interface with IP=XXX |
| 04/11/2020 10:47:39 PM - UDP transport is joined to SIP multicast group on interfaceXXX |
| 04/11/2020 10:47:39 PM - Folder for SSL certificates : /var/lib/3cxpbx/Instance1/Bin/Cert |
| 04/11/2020 10:47:39 PM - ** Initializing SIP stack ** |
| 04/11/2020 10:47:39 PM - Local IP addresses detected: XXXX |
| 04/11/2020 10:47:39 PM - [CM501006]: Default Local IP address: XX |
| 04/11/2020 10:47:39 PM - Default best-route IP is determined as XX |
| 04/11/2020 10:47:39 PM - [CM501002]: Version: 16.0.2.910 |
| 04/11/2020 10:47:39 PM - [CM501007]: *** Started Calls Controller thread *** |
| 04/11/2020 10:47:39 PM - [CM501001]: Start 3CX PhoneSystem Call Manager |
| 04/11/2020 10:47:39 PM - [EC200001]: Configuration server is connected: application:3cx2019:5485/DBProvider local:127.0.0.1:46864 remote:127.0.0.1:5485 |
| 04/11/2020 10:47:39 PM - Application connected:3cx2019:5485/DBProvider |
| 04/11/2020 10:47:39 PM - Startup completed for 3cx2019:5485/DBProvider |
| 04/11/2020 10:47:39 PM - Start management threads for 3cx2019:5485/DBProvider |
| 04/11/2020 10:47:39 PM - Timezone offset: -240 min. |
This would seem to be an important clue to the problem. But, as it also seems to be Linux (which I don't use), I'm afraid can't help you. You still haven't listed the version(s) you are using, which may help someone else diagnose the issue.04/11/2020 10:49:29 PM - Exception: DumException Cannot create new sessions when DUM is shutting down. @ DialogUsageManager.cxx:517
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
