SP4 Breaking Fqdn
cortel
Gold Partner
** It finally updated.**
I have had 3 of my clients that have updated to SP4 and when it does it reverts back to an Old static ip they had when the system was first installed.Inside the phone system it shows the correct ip address as static. but the fqdn does not work and when the customer logs into their portal it shows that static to be their old ip address. If i do a tracert to the fqdn it resolves to the old ip. Have restarted services but fqdn still not correct.
do you use local DNS server?
From where do you do a tracert? same location as pbx?
3K8iMGWviZ
