Solved SSL Certificate renewal failed
bchesnut
I have just upgraded my pbxexpress in SNAG-0912.pngAzure to the latest 3cx, before the upgrade I noticed the SSL certificate was expired, I am trying to renew the certificate now but getting this error:
How did you try to renew it manually?
Did you do a manual renew in the past?
It appears that the user owning the file has changed and can no longer be updated/accessed by 3CX.
never had to do it manually in the past, but it won't renew
SSH into the system and navigate to: /var/lib/3cxpbx/Bin/nginx/conf/Instance1
make sure that all files in the said directory have the following permissions:
-rw-r--r-- phonesystem phonesystem
Once done, try again and let us know if the issue persists.
Before running the command to renew the certificate (/usr/lib/3cxpbx/PbxConfigTool -renew-certificates)
switch to the phonesystem user with:
sudo su phonesystem
Thanks, that worked
If you are being prompted for a password after running a command with sudo, it should specify the user to which the password belongs to, which is most probably the user you are currently logged in with. That said, the SSH user created should have the same password as the one set for the 3CX Management Console.
Glad to hear you resolved this @bchesnut. If you require any further assistance, feel free to open a new thread.
Kayla Norris
