StartUP Pro UK SIP providers
perfectcast
HI,
For this service there are only 2 UK approved SIP providers.
I have a new client who wants the StartUP Pro as opposed to an onprem installation.
I see it is not allowed to use a generic sip provider.
This gives me a big issue. I'm sure the 2 UK providers are great but having spoken to both, neither provide the ability to select a range of easy on the eye numbers. I need a geographic straight run of 16 numbers starting with 000 for main reception, then 001-> 015.
My options appear to be
On prem solution with my existing SIP provider who has been great for 8 years+ who has a massive block of easy on the eye numbers.
Purchase numbers from my existing SIP provider and then port them to one of the 2 approved UK providers. This would be ok but the cost of the transfer is a non starter.
I understand from a support point of view why you are de-risking your side by only allowing approved SIP providers but this is probably going to result in a lost cliet for me. I am willing to take the risk with a generic SIP provider as I have used them for years with no issues and will continue to do so for on prem solutions
Can you enable the generic SIP provider? or propose something else. I dont really want an on prem solution for this client.
Neil.
Just use a dedicated instance.
StartUP will never have generics. It would defeat the purpose.
Why would you not just spin up your own VPS and charge client?
If not, send 'em my way and i'll take them.
RJenkinsROCK
