State management Teams & 3cx
Computer Republic
Good morning
I noticed that if I put Teams in "do not disturb" the DND status of the 3cx extension applies despite being "available" in the extension. So somehow Teams and 3CX have the "do not disturb" status in common, do you notice?
This "D&D" feature is only active in the Teams MOBILE APP.
If you set "do not disturb" into the desktop application, the extension is free but does not ring.
So the program behaves differently from a mobile APP to a desktop APP, when do you plan to fix this problem? If there is an integration it must work, otherwise it is better not to do it
Stephan Eusebe
