Stop external calls dialling ext numbers on IVR (V20)
Adrian-Blue
Gold Partner
I have a customer reporting that one of their exts is receiving external calls when it should not be. I have looked in the call logs and can see the caller dialled the ext number and connected directly. Is there a way for me to turn off extension dialling on a digital receptionist in V20?
You can use the DTMF call script to create your Digital Receptionist options. This will prevent people from dialling extension numbers.
I have never used used any kinds of scripts before. Can you give me a run down on what I need to do to set this up beyond the point of your screen shot.
Thanks.
youwillbrun
