Suggestion for Integrating a Drag-and-Drop CFD in 3CX PBX Console
TomyLe
Platinum Partner
1. Overview of the Need for a Drag-and-Drop CFD Integration
  • Currently, designing and deploying Call Flow Designer (CFD) in 3CX PBX requires the use of an external tool (3CX CFD), which is inconvenient and increases the risk of losing configuration files during handling.
  • Integrating a drag-and-drop interface for CFD directly into the 3CX PBX (similar to AWS Connect) would not only enhance the user experience but also optimize workflows and minimize the chances of losing created resources.
2. Benefits of Direct CFD Integration in the 3CX PBX Interface
  • 2.1. Enhanced User Experience (UX):
    • A drag-and-drop interface simplifies usage for non-technical users.
    • Reduces reliance on external tools, enabling users to manage everything within a single platform.
  • 2.2. Workflow Optimization:
    • Saves time by eliminating the need for importing/exporting configuration files or installing additional software.
    • Enables real-time changes without switching between multiple applications.
  • 2.3. Reduced Risk of Data Loss:
    • Configuration files would be stored directly in the PBX system, preventing loss or corruption when transferring files across devices.
    • Supports built-in version control and rollback options.
  • 2.4. Easier Integration with Other Services:
    • Facilitates seamless connections with APIs, CRMs, or third-party services without requiring complex processes.
3. Detailed Proposal for the Drag-and-Drop CFD Interface in 3CX PBX
  • 3.1. Interface Structure:
    • Introduce a dedicated tab or menu in the 3CX Management Console named CFD Designer.
    • Provide a drag-and-drop interface with blocks representing call flow components: IVR, Voicemail, Database Lookup, Call Queue, API Integration, etc.
  • 3.2. Key Features:
    • Drag and drop blocks to build call flows directly.
    • Integrate a simulation tool to test the call flow's functionality within the interface.
    • Enable advanced block customization for API calls or other complex operations.
    • Automatically save call flows and support version management.
  • 3.3. Integration Capabilities:
    • Connect with services like AWS Lambda, Twilio, or popular CRMs such as HubSpot, Zoho, and Salesforce.
    • Allow export/import of CFD files for sharing or migration across different PBX systems.
4. Benchmarking Against AWS Connect
  • AWS Connect is renowned for its intuitive and robust interface. 3CX can adopt and improve upon these features:
    • Strengths of AWS Connect: Drag-and-drop design, seamless integration with AWS services.
    • Improvements for 3CX: Tailored for SMBs, avoiding the complexity of AWS setups while maintaining simplicity and functionality.
5. Conclusion and Call to Action for 3CX Development Team
Integrating a drag-and-drop CFD directly into 3CX PBX will not only make the system more competitive but also deliver significant value to its users. A user-friendly interface, streamlined processes, and advanced integration capabilities will be a major step forward, aligning with modern technology trends.
We hope the 3CX development team considers and implements this feature in future releases. Let’s take 3CX to the next level in PBX technology!
  • Wow
Reactions: KoesioOccitanieTech
Upvote 4
