SuiteCRM Integration only passing first 6 digits to CRM look up
greychain
Gold Partner
Firstly thanks to Sergey123 for his SuiteCRM Integration. It works but for some reason 3CX is only passing the last 6 characters of the phone number. When testing in the 3CX Template generator it passes the correct number of digits.
3CX CRM template Generator
/Api/V8/module/Contacts?filter[phone_work][eq]=012620441
3CX Console Tes CRM
/Api/V8/module/Contacts?filter[phone_work][eq]=620441
Sorry found the answer 30 seconds later
You can configure this from the 3CX Console > Advanced > Contacts > Options. If you choose "Match Exactly" the full number will be sent.
https://www.3cx.com/community/threads/suitecrm-integration-problem.67026/page-2
intoxtech
