Supported or Not Supported?
AlexDBarrett
Gold Partner
Am I missing an update somewhere on the X4 where it is no longer supported?
Alex
The "Not Supported" displayed in the image is because the 7386 version of X4 is not certified for compatibility with 3CX. However, this does not affect your regular usage. I suggest you can ignore it and continue using it normally.
Teemal
