System not honoring Office Hours
PMadmin
Forum User
We recently upgraded from V18 to V20. At 2 of our locations the Office Hours are respected, but at our main plant, the system completely ignores Office Hours. I have combed through the settings and can't find what is causing that. Any ideas?
How are you testing? Call handling is set in the destination, e.g. the digital receptionist or queue, and needs to be set in all those places after the upgrade.
Ahh.... Thank you! I had the Destination if no answer set to a Ring Group. I thought the When office is closed route to setting was what controlled it. I changed the No Answer to a Digital Receptionist and now it works! Thanks again!
Sorry about that! Not sure why the double post. Couldn't figure out how to delete it.
Hmmm, "when office is closed" should apply but needs to be set. If "Accept Anyway" is selected (the default) it just uses the normal in-office routing and ignores office hours as noted.
The office hours used are those of the department to which the IVR, RG, etc. belongs.
LeeonLau
