Solved T53W no audio
Rej
Hi!
We have a T53W in a remote location provisioned by STUN. Our 3CX system is hosted in the cloud on a VM.
The phone has been working fine for a while. Suddenly, it stopped receiving incoming and outgoing audio.
The device itself is functional; we have audio in both the speaker and handset when pressing digits, the ringtone play when receiving a call, but there is no audio when making a call or trying the Echo service. The same issue occurs for voicemail or internal calls.
I attempted to factory reset the phone and have it reprovisioned. I also tried changing the ports for the RTP without success. I checked the firewall at the remote location, and all the ports are okay.
Phone calls go through, as it rings the internal extensions and external phone numbers, but once again, no audio is heard. I also experimented with PBX delivery options such as auto, invite, and others in the Extension tab, but without any success.
Why not convert it to a router phone? This sounds like a STUN issue and a RouterPhone configuration would solve it AND costs nothing.
Reactions: JohnS_3CX
Solved. I follow your advices. It's just weird it suddently stopped working when no changes happen in the system or the network.
Thanks !
Thanks !
I hear you, but something changed, likely something you didn't' have control over. It's one of the reasons 3CX says "it works great until it doesn't" in regards to STUN. It's why they push so hard for SBC/RouterPhone.
Perfect. The most important is that after setting up this T53W as routerphone it started to work :)
Finatra.us
