Teams and HA
JohanFer
Gold Partner
Hi All
Will Teams work with HA?
In the documentation it says "Navigate to your DNS provider and create a new A record to point to the static Public IP address of your 3CX installation."
SO this is only to the IP of the active site.
Regards
Johan
If you have 3CX failover installed among two machines using different Public IP address then the DNS for your FQDN IP will need to point to whichever machine is active at the time, same goes for your teams FQDN.
If using 3CX supplied FQDN for your 3CX installation this is handled automatically and so you will need to manage the teams FQDN DNS changes accordingly.
Reactions: JohanFer
I wonder if a CNAME from the Teams DNS to the 3CX FQDN (basically using that as IP) would work.
I am sure there was a test like this by design. I will try this.
Stephan Eusebe
