Teams call not via 3cx
JohanFer
Gold Partner
Good day,
Calling from teams while in a meeting works, I get some random number displaying. Not pat of my outbound ID's.
So the call is not though my 3cx.
Calling from the dial pad not in a meeting works and the call does go through my 3cx.
Inbound calls work fine.
Where can I stat to look?
Regards
Johan
Those numbers are actual calls in the PBX?
Hi Theodoros
The call made from the teams dial pad while not being in a meeting is a actual call in 3cx. But once I am in a teams meeting teams-teams and I add a participant by dialing a number, that call is not a actual 3cx call.
Regards
Johan
If the 3CX is not involved here you have to check this from Teams side.
Hi Theodoros
Can you maybe direct me to where to look for this problem in teams please.
As I mentioned. From the dial pad I can receive internal and external, as well as make internal and external calls.
But as soon as I am in a teams meeting, I cannot dial any internal or external number to join as a voice call.
Regards
Johan
You can not add 3cx users to the team's meetings. This will need to be done inside teams to another team user. This feature has no integration with 3cx.
Hi Charles
Than you for that. But I should be able to add a external participant by number?
This call is possible, but it is not routing through 3cx.
Regards
Johan
Still this depends on Teams.
Reactions: Charles_3CX
