Template import/generic-Providers are limited now... - Set P-Preferred Identity...
kaivonderchromit
I´ve run into trouble: The former HFO Telecom, now the Gamma Communications is a very good and fast VoIP-Provider, they use the Header P-Preferred Identity to enable the feature "Clip-No-Screening". In V20 all Providers are limited... In the indroduction, there was the sentence to import the Provider-Template for special configuraitons to solve the "not-so-really-finished" interface - ok, thats no problem! Imported the XML into the 3CX and the system was up and running - no problems, System = happy, Customer = happy, Provider = happy -> I'am happy.
Now we switched the Provider for one client and I cannot import a XML anymore ;-( I set up the Gamma Communications as generic to bring anything up and running, but I cannot not set the P-Preferred Identity-Header anymore, the only ones I can choose from are:
  1. From : Display Name
  2. Remote Party ID
  3. P-Asserted Identity
Is there a way to bring the additional settings back? (They are quite useful - belive me ;-))
And btw.: Is there a plan to "re-connect" the Gamma Communication as certified provider?
Sincerly
Kai
The additional settings can only be done with an imported template.
The importing of provider templates has moved to the templates page. It is no longer under the providers page.
tohoken1
