Solved Test giving The 'file' scheme is not supported.
av42
I manage to authorize the Zoho CRM integrations successfully but when using the Test button I get The 'file' scheme is not supported. I saw another post with the same and the template version is 37 I'm on the latest version of 3CX don't know what else to check.
Thank you
Please also check this forum post regarding the error you receive.
Thank you
Can you post the log where you're getting this error? Maybe a screenshot? That could give us some hints....
I just managed to fix it now. I needed to authorized the integration again. So basically you need to authorize the integration twice in case this error message shows up. It can be marked as solved. Thank you all for your support
NortechTelecom
