Solved testing ports [9000..9398]... failed
chrisjako
I have triple checked the firewall rules and the range is in there but the firewall checker is showing this issue
What is your firewall?
What is your OS?
Have you rebooted the router as there could be something messed up with routing.
There was some maintenance work being done on our STUN servers that might've caused this issue. Could you give it another try now?
Yes perfect now thanks!!
Glad to hear it works now @chrisjako! Feel free to open a new thread if you require any further assistance or information.
Bluebox Global
