- Joined
- Feb 24, 2021
- Messages
- 32
- Reaction score
- 12
3CX has trouble with spaces in forwarding rules. The call will simply be dropped and users are not prevent from entering numbers in this way.
Spaces are not a problem when using the input field of the phone client. In this case spaces are accepted and obviously ignored.
This kind of inconsequent behavior doesn't make any sense. Of course, users expect it to just work if they put the same number in the same
format into a forwarding rule.
Why are threads like the following being closed and even marked as solved?
https://www.3cx.com/community/threads/spaces-in-mobile-number-forwarding-failed.84766/#post-397092
https://www.3cx.com/community/threads/remove-spaces-in-outbound-trunk-rules.64418/
https://www.3cx.com/community/threads/mobile-phone-field-and-blank-spaces.85794/
This is not even solved in v18. Anyone who just glances at E.123 - or DIN 5008 for Germany - will see that human-readable phone numbers contain spaces. The standards might encourage or even require certain positions to place the spaces but as handling a phone doesn't require a lawyer or a PhD - not that any of that would actually help - but a average people will place spaces at arbitrary positions.
What is the actual problem with post-processing phone numbers and removing those spaces?
