Solved Traditional Chinese language interface roadmap for 3CX desktop softphone
PeterCheng
Forum User
Hello sir,
I'm from Taiwan and we're using traditional Chinese. Because right now there's no such language in your desktop UI. (There's only simple Chinese, and that's used for mainland China)
I'd like to know whether you have roadmap to add Traditional Chinese as an option, it will helpful to expand our business in Taiwan , thanks.
Peter
Reactions: PeterCheng
Hello sir,
Thanks for your explanation.
I heard from our partner and they said that they had propose this idea to you, and they also provide traditional Chinese translation file to you.
They have implemented the option on Web client UI, and it works.
I hope that you can spend some time and help integrate the tradition Chinese language pack with your app.
Thanks you so much.
Peter
Hi @PeterCheng,
Thanks for coming back to me. If you partner has already proposed the idea to the ideas forum, then I'm sure given enough traction, it may be considered for a future implementation.
FringeIT-Eric
