- Joined
- Dec 19, 2007
- Messages
- 145
- Reaction score
- 0
Hi all;
I really don't know where to post this issue (freepbx or asterisk) so I decide post it here. If somebody don't feel comfortable with this subject I will move this to another section (suggestion are welcomed).
I have two systems connected via sip trunk. 1. is Elastix 2.02 and the second is Cisco Call manager 8.x
All functions work fine, I can make calls between both systems.
Some users from CUCM have migrated to asterisk, but they need to be accessible on the old number in CUCM - so they have simply "forward all" active ith target number on asterisk.
All calls from pstn, trunks or other CUCM users are forwarded to the asterisk extension and everything is fine.
When any asterisk extension try to reach the CUCM number and call is being forwarded back to the elastix (asterisk) - asterisk see the invite with his own extension from trunk - send auth request and do not get response, so simply send the unauthorized 401 SIP message and CUCM drops connection.
I have insecure=invite,port on trunk set on the trunk but it does not helps.
The question is - what variable should be set on the trunk to get connection in the scenario described above.
I know all the numbers on the second system, so my idea is to tell the asterisk that calls for some external numbers should not be forwarded to the trunk but directly to the specified extension. (I have to forward all numbers 8XX to the trunk but some of them are returned back to the asterisk to 58XX extension)
Does anybody have idea how to do such a translations/routing rules on the elastix/asterisk/freepbx?
