Solved TTB to TTB SIP Trunk On-Net Calls strip FROM and replace with PAI Header
Scott Magee
Gold Partner
Hi all,
I've posted previously asking for help with calls between 3CX systems with TTB SIP Trunks as they always display the wrong Caller ID.
I have provided captures that prove that both 3CX systems are sending the correct FROM caller ID and this is only an issue when both systems are using TTB/Tipicall SIP Trunks.
The original post was closed for comments as I had to go back to TTB for help and after about 2 months, I have finally received the response below:
"Sorry about the delay on this, our 3rd Line have informed me the presented number is being stripped and replaced by what is presented in the PAI header. This is set network behaviour for on-net calls and not something that we can change on our end.
To resolve the issue for your client they will need to change what they are presenting in the PAI to the to the number they want to present."
Whilst this explains the behaviour, I'm not sure how I resolve this?
Can anybody help?
Scott
Hello @Scott Magee
You will probably need to configure the P-Asserted identity sip field under the outbound parameters of your trunk.
11225
In the above example the PBX will send the outbound caller id that is set under the extension settings. If that is empty then it will send the main trunk number.
Reactions: Scott Magee
Thank you YiannisH_3CX, that has fixed it!
I'm so grateful, this has been going on for months!
Glad i was able to assist
devo.it
