Twillio Outbound
Yilmaz
SOHO User
I have configured some Twillio trunks but having an issue with the outbound calls regarding outbound rules but I have set it up
If used the same configuration for other providers and it works
Hi @Yilmaz
Make sure E164 processing is off and check your outbound rules again.
I do not see any setting for outbound E164 in the outbound rules
In trunk settings I see E164 setting for inbound
I do not want to change those as the inbound is working
You would need to uncheck the E164 processing
This would basically send your calls out as dialled without modifying the number on your behalf.
Then check your outbound rules.
Yes my E164 processing was switched off
I have assigned the extension to the outbound rules In trunk but it still
Says there is no outbound rule for the extension
Can you check your Twillio log and see what it said too?
it is not reaching Twillio
Post a screenshot of your outbound rule if possible.
I have tried both outbound number to display as 07 & +447
Remove all restrictions in the outbound rule apart from the extension 114 and try making a call from extension 114. Does that work? How are you dialing the number from the users device?
What do you mean remove restrictions
When I want to dial
A UK number the number for example will be 015827226767
So I will dial that number
I have removed the 1st digit which is 0 and prepended +44
Okay, I have an update regarding this, Inbound calls work okay with Twillio, but Outbound calls do not work, however, I can call outbound with my Telnyx account, I wish to migrate from Telnyx and move all my numbers over to Twillio but am unable to get the outbound calls working.
Ok I have another update however still not calling out of Twillio
In the Twillio I have created an SID and private key for that specific trunk plug the credentials in the 3cx and it’s still not working
Inbound calls and inbound sms works on mobile
Inbound calls on landline number works but can not get the 3cx to dial out using the Twillio trunk and it doesn’t seem to be reaching Twillio to get the logs
Have you looked at the 3CX Activity Log (Verbose) to what issue the PBX actually has, with the call?
not sure how to do this
If your version has it available, it will be...Admin Console, Dashboard, then scroll down to Troubleshooting...Activity Log.
Under Settings, you can change the Logging Level to Verbose if the current level doesn't provide enough information.
You may need to place another failing call, then check the logs (refresh).
tohoken1
