Solved Two instances running with the same Enterprise license
davide.bonavita
Hello fellow colleagues,
sorry but my google-fu skills are low today, could you point me to the documentation/best practices about running two separate instances with the same Enterprise license and with two separate FQDNs? I'm trying to serve our European and American clients with two instances, each one located in each region, and bridged together.
Hope it makes sense!
Thank you
What you want to do is not possible, you would require two separate licenses
You can run two instances using a enterprise license, but this is for 3cx failover setup where it uses the same license key, fqdn
Have you thought about putting the server in the cloud,
ahhhh, that's why I could find anything about this. Fair enough then, thank you!
Reactions: NickD_3CX
intoxtech
