two separate 3cx systems in the cloud, two companies, comingle options?
dapdacompx
Forum User
I have a customer that runs two companies at the same location and wants to be able to have the same user answer / make calls for both companies, each company is its own separate instance of 3cx hosted cloud running. Thoughts?
I suggest bridging the systems together so that calls can be made and received via one extension on either PBX.
You would need to set up some inbound and outbound rules to accomplish this, and you can find all our guides to achieve this here: https://www.3cx.com/docs/manual-u5/
OR you can wait for update 6, from where you can set up groups and manage both companies on one PBX instead: https://www.3cx.com/docs/manual/
TVV40
