Solved Unable to call UK Landline numbers
Binoy
Hi Guys,
I have DID Logic SIP (UK) trunk and able to call UK mobile numbers, unfortunately unable to call UK landline numbers.
07/26/2022 4:09:53 PM - Call to T:Line:10001>>44161612XXXX@[Dev:sip:[email protected]:5060] from L:49.1[Extn:XXXX] failed, cause: Cause: 603 Declined/INVITE from XX.XXX.XXX.XX:5060
Can someone help me to resolve the issue.
Thanks in advance
Cheers!
Linto Anto
Regarding your question, what is the IP address that is X'd out? XX.XXX.XXX.XX:5060, presumably this IP address belonging to the VoIP provider? If so, then this will be where you need to check why they are declining the call with a 603 sip message.
What have you got doing the E164 conversion? if you dial a 0 instead of 44 does it work?
Hi Charles,
It is DID Logic SIP IP
If you check the Activity Log, are numbers to landlines, in the same format? No + , or other prefixes, ahead of the 44?
If the numbers are the same format, it might be a caller ID issue, where the mobile provider that the call is passed to doesn't care, but the provider handling the landline call is a bit more picky.
Thanks for your support.
Issue resolved, it is just because of the per call price limit calls were declined.
Cheers!
Linto Anto
Reactions: Charles_3CX
I am glad your issue is resolved, but as stated, and for future reference, it is always best to check with the provider first since they are the ones rejecting the calls.
Diogo Maia
