Solved Unable to change voicemail access code
CSerpent
I've used 3CX's deploy to cloud option and successfully deployed to Azure.
The only problem I seem to have is that this is a UK system but it's got the voicemail access code set to 999, which is obviously a bad thing! I've checked under settings/general... not there any more, have however added 999 and 112 as emergency numbers. I've looked in parameters and can't find it there either.
Has anyone any suggestions, please?
Go to Settings > Voicemail and change it there.
If you require any further assistance, feel free to open a new thread!
devo.it
